Possible to edit the M6 macro?
Is there a way to edit the M6 macro?
on my firmware the probe speed is f150 that is super slow.
so i want to increase it somehow.
Second thing .
I have a spindel, But gsender always starts up with anoter spindel as default.
If i choose my spindel i get an alarm and it will not spin up.
So i need to always to select the right spindel before starting the job, then it works just fine.
is this a Bug or something I am doing wrong ?
thanks
@sveininge79 I don’t know that the M6 macro is, but I’m sure that others here will.
What controller are you running? It sounds like you are not running a Sienci controller, yes?
its the super long board i have
@sveininge79 You can set your default spindle in the firmware. Take a look at the Techncal document for the SLB in the resources section of the Sienci website. It will show you what values to change.
