Probing section should remember tool diameter between executions.
Make touchplate type selectable from the main screen instead of the settings dialog.
Provide a settable z-axis retract to be performed when probing is complete. Setting should be remembered between executions.
We’ve added in your first suggestion, the second we likely won’t do for now
Could you explain the usability of your third request?
2 posts were merged into an existing topic: Setting to raise bit after probing
@ColonelClarence I realized there was already another existing request for this! I understand what you’re wanting now. I’ll close this now since the other two items are implemented, and I’ll update the other Topic if we make more progress on this request ![]()
