Project size larger then should be
My altmill is cutting out projects much larger than it should. No errors but it comes out 3 x bigger.
Hey Geoffrey,
Most times when the visualizer displays a job in a weird size it’s due to using a post processor that gsender cant work with. There are some examples with solutions in this very forum. Funny enough they usualy have trouble with too small sizes.
So, it might not be your problem, but it might be something to look into.
Info on post processors to use with different cad software are found here:
Worth a shot.
The display is the right side and scale, altmil moves twice as fair in comparison to the display. I’m thinking my stepper settings are off. Not sure where.
Owwwws, that could be a thing. Have you looked at calibration tools, if that can solve something?
Issue was dip switch on x axis, was sure it was right. 🫨
