Putting Altmill mk2 on a table in enclosure
New Altmill mk2 4x4 owner here. Very excited to be part of the community. Assembled my unit and basic tests check out. It moves. It homes…etc. Note that I don’t have an ATC, but I’m using the air cooled 2.2kw spindle.
It is in my basement and I cannot use it until I build an enclosure for it. There is a really good thread on enclosures here Been hiding with an Altmil 2x4 build! - #80 by Imisky but there were a couple of things I didn’t understand.
Should the machine not be seated directly on the wood platform below and elevated slightly?
Does the machine need to be secured to the wood below or can its weight keep it down? The machine has so much power it is almost scary
What spoil board arrangement do you recommend for one that has an enclosure?
I have some woodworking experience and have scanned a lot of ideas for enclosure. I’ll be building something with removable panels to give me access from all sides paired with a powerful dust collector.
Thanks in advance!
Welcome to the group!
Not an AltMill owner but I think that had to do with accessing some grease fittings.
This was for a much slower machine, a Sainsmart 4040 but I 3D printed some ‘feet’ for it. The feet were fastened to the table and the corners of the frame went into a curved slot that matched the frame corners. That kept the mill in place while allowing it to be picked up and moved if needed. Maybe something like that could work if built strong enough. Just a thought.
I think comparing that Sainsmart to an AltMill is kind of like comparing a bunny rabbit to a bucking bronco with it’s tail on fire so bear that in mind!
Hey, thanks for finding my build thread interesting.
Not necessarily need, the Altmill itself sits on legs without the center cross beams being supported. This is how I currently have our machine setup as well. Having said that, there is deflection in the middle of the table when force is applied. So if you are after micron level part accuracy, and plan on cutting hard materials like aluminum, it’s worth looking at addressing the deflection. For us, we plan on adding supports to the center of cross beams.
If you aren’t going to use the legs that come with the unit. it’s best to hold down the unit to the table surface.
You’ve got choices, and it will depend on what you want to do. but I would think about your use case. The spoilboard has less to do with the enclosure, more to do with how you foresee holding down your work piece.
  • MDF spoilboard, just use screws where ever you see fit to hold down your material (I use it still)
  • rails to add clamps, with MDF spoilboard, maybe dog holes, and side clamps
  • fixture plates, delrin, aluminum, your pick of material.
Thank you @_Michael and Eugene @Imisky ! I found the greasing nipples after a closer look and I underhand that issue with trying to raise it to make those more accessible. As far as deflection, I am contemplating a torsion box underneath the CNC. There are some logistical challenges finding a completely flat space on which to construct a 72x72 inch torsion box then lifting and transporting it to my basement. Doable with 1/2 inch plywood but I would need a lot of help if I use 3/4 so haven’t made up my mind yet. My floor is not perfectly level so I need a leg solution that accommodates that as well. I don’t see myself building a whole cabinet underneath, at least not right away. It’d take too long and I want to be using my cnc sooner than that!
I’ve actually reused the Altmill legs as part of a workbench so you can absolutely attach those to a torsion box. and then use the Altmill legs for additional shelving. So its totally viable, or you could just use the Altmill as intended with the legs and not a table.
I haven’t shared this as it was a new development lately, but the cabinet under the Altmill was probably unnecessary in the grander scheme of things. The shop vac we had was just loud and maybe old…it died recently…There are better shop vacs nowadays. We bought a new Dewalt shopvac for dust extraction for the Altmill and it’s so quiet out of the cabinet that it had me questioning the build of the cabinet. With the shopvac in the cabinet…We don’t even hear it at all. Now all we hear is the sounds of the endmills cutting the material and air compressor.
I just built a table and enclosure for my altmill 4x4. I cut the included legs down to about 4 inches and welded piece of angle iron across with a hole drilled for the leveling feet. Didnt have to worry bout torsion table. I just level the machine on the table same as you would with full length legs.
Thanks @rhyder . Did you secure the machine to the wood surface? I’ve been reading up on the Shapeoko 4x4 forums where they don’t supply it table and they don’t recommend securing it due to wood and metal expending in different ways
Thanks!
Another question for @Imisky and @rhyder .
My lower frame is almost ready but I realized the horizontal stretchers (bars) are not flush with the left and right Y rails on the bottom of the machine. They stretchers are 1/16 to 1/8 higher. Putting the cnc on a table means it is only supported by the sides unless I introduce a thin shim that supports the front and rear stretchers. Did you guys worry about this? The original table legs bolt into both the sides and the front/rear stretches distrubuting the weight a little better.
Thanks in advance!
@Osaman88 I certainly would not worry about it. The cross rails don’t really support anything except the spoil board.
@Osaman88, @Chucky_ott is correct on this. The only thing I’d look into is whether or not you want to address the deflection of the cross beams that support the spoil board. Many go without extra support.
If you are concerned, and have a dial indicator can you simply park the indicator in the middle of the span, and just press down by hand, you’ll see how much deflection you get, if you think that’s ok, leave it unsupported, otherwise support it accordingly.
The only thing to really check is the zerk grease nipples in the left and right Y axis motion systems rails Make sure your Altmill is lifted high enough for those to clear the surface, or you risk dragging them and damaging the hardware.
