Robb kindly provided his openSCAD files and his .stl files for his take on a mid-century TV cabinet featuring remarkable hidden joinery. The cabinet houses an older smart phone.
Here is a link to his post with pics of his completed project:
Here are the zipped files of the scad files:
parametric_box - v1.6.scad.zip (2.6 KB)
tv_case - v1.3.scad.zip (5.0 KB)
Here is the zipped file for the stl files
stl files.zip (3.1 MB)
Edit: Rob has updated these files from the previously-posted versions
Updates in these versions:
Corrected a bug in the finger joint positioning (opposite sides of a given panel were not quite in alignment)
Made the spacing between parts a function of the router bit diameter so it resizes automatically if a different bit is used
Rotated the right-hand side of the box in the machining view so the orientation of the grain will be consistent in the final box
