Hi all,
In gSender 1.0.3 when I try to z probe it travels down a very short distance (~1-2mm), shoots up, travels down a short distance again, shoots up, then stops. It travels down such a short distance that to safely get the tool in position I may as well manually set the z height.
The tool tips for “fast find” and “slow find” say “specify starting point between touch plate and tool” but the units are in mm/min. I suspect they are actually speeds because there is no way it is traveling the default value of 150.
Does anyone know how to set the travel distance of the probe, or alternate free or non subscription software that supports xyz probing? (I tried UGS, it doesn’t run properly on my Win10 computer for whatever reason.)
Thanks for your time.
