Skewed Test Pattern
Something for the Laser guru’s to chew on this morning. I was running a burn test on pine, created in Lightburn and run in GSender. The squares are supposed to be .5" X .5". When it loaded into GSender, the Y height was closer to 1.25" (hence needing to add the second board for the test pattern).
Once the last row was started, the X became 1.25" for 7 lines, then it magically shifted back to .5" in X, however the entire pattern was shifted 3" to the right. After a few more lines, the pattern shifted again, this time about 9" to the right.
Any thoughts or suggestions?
@Wood_n_Peg Can you post your gcode, pls, Tom?
Didn’t want to create a long list so I mailed it to you. (hopefully)
@Wood_n_Peg I got it, Tom. I’m heading to work for a while,but will look at it when I get back.
