RichL
September 21, 2020, 4:20pm
1
I am having issues with tightening the eccentric nuts on the Z to X axis mounting. The V groove wheels do not get tight along the path of the extruded aluminum rail.
I spent at least an hour assembling/reassembling the Z Axis carriage but, still could not get it to fit tight on the X Axis rail.
gwilki
September 21, 2020, 7:32pm
2
@RichL Welcome to the group.
This is a first, I believe. Just to confirm, you have adjusted the eccentric nuts as far apart as they can go and the wheels are still not tight?
RichL
September 21, 2020, 8:14pm
3
Yep exactly. The eccentric nuts are pointed down with the shaft as close as physically possible to the x axis rail.
The picture is a result.
CRD
September 21, 2020, 9:00pm
4
I think this is one for Andy to deal with. Something is not assembled correctly or machined correctly.
I had the sane issue and Sienci was very responsive and I should have a new X-rail this Friday.
RichL
September 22, 2020, 10:54pm
6
Were you able to measure the angle or spacing on your rail?
RichL
September 22, 2020, 11:17pm
7
I located the CAD model for the X-Axis Rail shows a distance of 107.763 mm between the two edges that the V Wheels ride on.
I measured 106.86 on mine, it might also vary slightly since my machine is put together, and is hard to get an accurate reading with the calipers.
I also checked the Steel Plate for the X-Axis Gantry and it seems really close to 126.820mm shown on the CAD drawing.
Thanks. I’ll check it tomorrow afternoon. I should be able to measure the X rail where it comes through the end plate.
