I made sure the toggle the option on in the firmware tab but it still not appearing after I upgraded to 1.2.1. Anyone else running into this issue?
Not sure if this is what you meant by the firmware tab but there is a toggle in settings under spindle/laser that has to be enabled. By settings I mean the cogwheel icon in gSender.
As a side note if you are talking about $32 in the firmware, which is also a toggle, you should not have to change that manually, it should change automatically when you switch from spindle to laser and vice versa. $30 and $31 should also change automatically to the values that you set in the settings.
Ah yes forgot about settings under the cogwheel icon, thanks a lot!
