Spindle weight of 2.2Kw
have a mk2 w/extension kit. Can it handle the weight of a 2.2Kw spindle without sagging? Thank you, bob
@bobblack1 Welcome to the group, Bob. Do you have the LongMill Mk2 or the AltMill Mk2?
sorry about that, Its a longmill mk2 w/extension to 48" bob
@bobblack1 I donโ€™t know from personal experience. Sienci says the following for your machine:
" Router / spindle: can run in 15000 โ€“ 25000 RPM range with reliable speed feedback, 0-5V PWM control for spindles. Router / spindle cannot exceed 2.7kg (6 lbs)."
The 2.2Kw spindle weighs about twice the recommended maximum. Itโ€™s noteworthy, I think, that on the store page for the 2.2 kw spindle, only the Altmills are listed as machines to add it to.
FWIW, IMHO, I believe you are asking for problems if you go ahead with this.
thank yo,. I am glad I asked. You probably saved me a lot of aggravation, bob
@bobblack1 Youโ€™re welcome. What are you running now vis-ร -vis router/spindle?
I had the Longmill MK1 with the 48โ€™ Extension with a 2.2Kw Spindle and it was able to hold it no problem with no sag.
I have since upgraded to Altmill MK2 with the same spindle, but the Longmill worked flawlessly, I just needed the 4x4 space
I have a 2.2kw air cooled spindle on a 48" MK2 with no issues
