Update: now on gSender 1.1.1: Start button still dead after restart, laser offset still stupid
Start button died during recent job, But start from line 1 worked. It was fine after quitting and relaunching.
Switching between Laser and spindle applies the recorded offset to the workspace crudely, by assuming that the previous location was X0Y0, rather than actually applying a correction to the actual X and Y positions.
gSender just notified me there is a new download available, and says it is downloading, but nothing came of it
Also if I close the main window. gender is still there but it probably should quit as it is thenceforth a zombie.
If I remember correctly, those were the exact problems that 1.1.1 was supposed to fix from 1.1.0. Seems like you didnât get the upgrade installed. (I now notice that you edited the OP.)
Both of these issues are fixed in todays release - laser offset properly accounts for wpos when toggling on and off, and the issue with the start button in some situations. In the meantime, if you have a start gcode block thatâs enabled but empty, you can disable it to have your start button working again.
