new to gsender. i dont have a longmill yet i have a different machine how should i set up the machine settings my machine is not listed. also i dont have a square probe i have a puck do i have to change the setting.
@langlois Welcome to the group Joseph!
If you are talking about the list of machines in the firmware section, Iβm pretty sure they are just for flashing the firmware which isnβt needed if your machine is working.
As far as the puck, in the Probe section of the Settings select Z Probe and enter the thickness of your puck. After you do that the Probe Tab at the bottom right will change to reflect your type of probe.
