Is there a way to set cut depth and bit diameter defaults for surfacing using gSender? It retains the speed and stepover, but reverts back to .04 cut depth. I alwas start at .02 on every project and have to change this every time.
Hello! I create my surfacing tool path in VCarve Pro. I surface most projects before actually carving them. I hope this answers your question!
Jake
I use VCarve desktop. Now Iβve got a 4080 machine, so I have to use gSender to get part the 24" restriction.
Hey Brian,
If gsenderalways reverts back to 0.4 and you want 02, maybe you can set your z0 02 higher and your good to go.
I know, itβs not a lasting solution, but now at least you can work around the problem, no?
@BrianV What version of gSender are you using? I have 1.4.12 on a test uno and, after disconnecting, shutting down gSender, re-starting gSender and re-connecting, the values stay where I set them.
