I just ran the surfacing function, and it left a mohawk strip, 6mm wide, down the centre on my board where it didnt cut. Anyone else seen that? Ver 1.06.
This is pattern the system generates, the gap in the middle is noticable in the visualizer
Thanks for the report, we should have a fix for this in the next build - given your original inputs, the gcode generation should now properly finish the center of the board using the spiral pattern.
