Tool change
Hello,
I am generating G-code using Estlcam.
During the tool change performed by the gSender wizard—using the “standard re-zero” strategy—the new tool passes too close to the work surface.
If the workpiece isn’t perfectly flat (which often happens), the tool leaves a nasty scratch.
How can I increase the “air-travel” distance at that specific moment when cutting resumes?
The clearance height is set correctly at 5 mm, but that setting doesn’t affect the resumption of work—I’ve already tested it.
Thanks in advance for your help.
