Just received my standard block touch plate from sienci labs and hooked it all up. I set my xyz with a .25 end mill. I swap it out for a .25 90 degree V bit and set my Z. I double check everything at the end by XY0 and “go to zero z” and everything looks good. I hit start job and my z axis goes straight up and starts moving to the top right of my machine ( outside my cutting perimeters. Has anyone had this issue?
Can you share your gcode? At least the first 15-20 lines
client $$
$0=10 (Step pulse time, μs)
$1=100 (Step idle delay, ms)
$2=1 (Step pulse invert, mask)
$3=5 (Step direction invert, mask)
$4=1 (Invert step enable pin, boolean)
$5=0 (Invert limit pins, boolean)
$6=0 (Invert probe pin, boolean)
$10=1 (Status report options, mask)
$11=0.010 (Junction deviation, mm)
$12=0.002 (Arc tolerance, mm)
$13=0 (Report in inches, boolean)
$20=0 (Soft limits enable, boolean)
$21=0 (Hard limits enable, boolean)
$22=0 (Homing cycle enable, boolean)
$23=0 (Homing direction invert, mask)
$24=25.000 (Homing locate feed rate, mm/min)
$25=500.000 (Homing search seek rate, mm/min)
$26=250 (Homing switch debounce delay, ms)
$27=1.000 (Homing switch pull-off distance, mm)
$30=30000 (Maximum spindle speed, rpm)
$31=0 (Minimum spindle speed, rpm)
$32=0 (Laser-mode enabled as spindle, boolean)
$100=200.000 (X-axis travel resolution, step/mm)
$101=200.000 (Y-axis travel resolution, step/mm)
$102=200.000 (Z-axis travel resolution, step/mm)
$110=4000.000 (X-axis maximum rate, mm/min)
$111=4000.000 (Y-axis maximum rate, mm/min)
$112=3000.000 (Z-axis maximum rate, mm/min)
$120=750.000 (X-axis acceleration, mm/sec^2)
$121=750.000 (Y-axis acceleration, mm/sec^2)
$122=500.000 (Z-axis acceleration, mm/sec^2)
$130=812.000 (X-axis maximum travel, mm)
$131=812.000 (Y-axis maximum travel, mm)
$132=105.000 (Z-axis maximum travel, mm)
ok
client $J=G20G91 Z1250 F94.488
ok
client \x85
feeder $J=G20G91 Z-0.04 F118.11
ok
ok
ok
ok
ok
ok
ok
feeder G10 L20 P1 X0 Y0 Z0
ok
feeder G91 G20
ok
feeder G38.2 Z-1.2 F5.9
[PRB:0.000,0.000,3.025:1]
ok
feeder G91
ok
feeder G0 Z0.15
ok
feeder G38.2 Z-1.2 F2.95
[PRB:0.000,0.000,3.005:1]
ok
feeder G10 L20 P1 Z0.59
ok
feeder G91
ok
feeder G0 Z0.15
ok
feeder G0 X-0.797
ok
feeder G0 Z-0.591
ok
feeder G38.2 X2 F5.9
[PRB:-13.105,0.000,-8.255:1]
ok
feeder G91
ok
feeder G0 X-0.15
ok
feeder G38.2 X2 F2.95
[PRB:-13.065,0.000,-8.255:1]
ok
feeder G4 P0.3
ok
feeder G91
ok
feeder G10 L20 P1 X-0.518
ok
feeder G0 X-0.3
ok
feeder G0 Y-0.797
ok
feeder G0 X0.797
ok
feeder G38.2 Y2 F5.9
[PRB:-0.385,-13.235,-8.255:1]
ok
feeder G91
ok
feeder G0 Y-0.15
ok
feeder G38.2 Y2 F2.95
[PRB:-0.385,-13.190,-8.255:1]
ok
feeder G4 P0.3
ok
feeder G91
ok
feeder G10 L20 P1 Y-0.518
ok
feeder G0 Y-0.15
ok
feeder G0 Z1.04
ok
feeder G0 Y0.843
ok
feeder G90
ok
feeder G90
feeder G0 X0 Y0
ok
ok
ok
ok
client \x85
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
feeder G21
ok
ok
feeder G91 G20
ok
[PRB:0.145,0.020,-5.335:1]
ok
feeder G91
ok
feeder G0 Z0.15
ok
[PRB:0.145,0.020,-5.360:1]
ok
feeder G4 P0.3
ok
ok
feeder G91
ok
feeder G0 Z0.15
ok
feeder G90
ok
feeder G20
ok
feeder G90 G0 Z0
ok
ok
ok
client \x85
(M6)
G17
G0Z7.620
G0X0.000Y0.000S16000M3
G0X69.933Y88.799Z5.080
G1Z-1.047F1270.0
ok
ok
ok
G1X69.538Y88.542Z-0.929F2286.0
ok
X68.356Y88.628Z0.000
ok
ok
X69.165Y87.439Z0.000
ok
ok
X69.933Y88.799Z-1.047
ok
X70.289Y88.686Z-0.828
ok
X70.527Y88.650Z-0.718
ok
X70.798Y88.653Z-0.635
ok
X71.059Y88.711Z-0.608
ok
X74.051Y89.728Z-0.626
ok
X74.316Y89.787Z-0.657
ok
X74.608Y89.791Z-0.749
ok
X74.907Y89.741Z-0.894
ok
X75.083Y89.692Z-0.997
ok
X75.044Y89.353Z-0.807
ok
X74.986Y89.139Z-0.712
client !
client \x18
ok
You’re in inches mode, but looks like your gcode is mm. Or you designed a platform for a large bed.
What CAD/CAM program? What post processor?
Hmmm well I use vetric aspire and then g sender. After the touch plate failed I just used the paper trick and it worked as normal. Ives been doing the paper trick on gsender as usual. The only thing I changed was update gsender before I hooked up the touch plate for the first time.
Can you upload your gcode file?
I use G code ( inch) (*.tap). I appreciate the help. If I use this file and zero xyz using the paper method I have no issues. When i use my probe, that is when i have issues. When i start my job it goes all the way up on my Z axis and then my cnc moves past my cutting perimiters of 11.25’’ by 11.25’'. Aslo moving the X and Y axis to the top right position.
g code 90 v bit.txt (321.5 KB)
The file is in mm, but there is no unit of measurement in the gcode. A decent post processor will always include a G20 (in) or G21(mm). Your gcode does not. Based on the fact that there are numbers in the 260 range, I would assume the post is a metric one. You were most likely already in inch mode in gSender, so the machine was trying to make a sign 20 feet across.
Add a G21 to your gcode, and that won’t happen.
This is one reason I was asking about the design software in use (on the other forum.) The OP started posting a gCode file, so it had to come from somewhere. ![]()
Thank you so much for resolving the issue. I was definitely using the wrong post processor. The touch plate is perfect. I should’ve gotten this thing a year ago.
