Touch plate setup
I have an open builds lead 1010 trying to set up G sender with an existing open builds touch plate. Can someone help/guide me through the setup process in G sender for an open build XYZ touch plate? Any help would be appreciated and thank you.
Hello Paul,
Welcome to the forum. Can this section of the gsender manual help you out?
thank you, . I will check the link out and see if that will help.
