Touch plate trouble
Machine all set up. I am able to move manually all axis. I’m trying to set up with new style touch plate. I changed in setting to new touch plate but when I start, the probe goes and touches all axis then should go to cutout corner of plate and stop but it goes the opposite direction and breaks the bit on the plate. Any ideas? Thank you. image|375x500
I have a similar problem and have not been able to find anything.
Im unable to get any response from my touchplate
I actually figured out for my situation , was not using in front left hand of Machine.
@Banderson In the current version of gSender, you can select any corner if you prefer not to use the default left front. Just an FYI.
Had this same problem and disassembled the connector on the magnet and found a connection that was crimped on the isolator and not on the wire core.
I now have same problem, and suspect a broken wire, but I don’t use the probe anymore. I have found that using a light and stepping down untill no more light bleeds between bit and material is good enough for me.
