Tramming the ATC
Hi,
Does the ATC get trammed? I understand the process for the normal spindle, but didn’t see anything on tramming the ATC. Is it similar to tramming the normal spindle, or something different.
Thank you.
The process should be exactly the same as the regular spindle.
Thank you. I wasn’t sure if I would have access to the same fastener for use with the bushing for tilt. Nod still shimmed?
Squaring & Tramming - AltMill - I would refer to the canonical documentation for this
