Trouble loading the finishing pass Gcode on Gsender
Hello fairly new to the 3d carving. Had zero issues with my first couple carves but am now experiencing a loading issue on my current project. Its set up in easel then downloaded and ran through gsender. I did roughing pass without issue but will not load the finishing pass gcode. the file size is 124 mb i’m guessing its a size issue but would like to find a way to make it work to finish the project. im able to select the file, it shows the load bar gets to 100% but just stays like that and never actually loads. ive re downloaded the file several times and restarted computer/programs and so on and cant get it to work. Any help would be greatly appreciated.
@NewfieWoodworker There was a discussion quite a while ago about file size restrictions in gSender. You can search the forum to read up on it. In short, if I understood @KGN correctly, there is no file size restriction. Your issue may be a limitation of the PC you are using to run gSender. (I’m speculating here.)
That’s a huge file. An option may be to split it into smaller files.
If you have a cloud storage account and can upload the file to it. I can take a run at it if you like. I can see if I have the same problem.
