Hi, My laser will operate but not actually burn at the rate of speed in existing examples. For example, the testing pattern demonstrated in the first live stream doesn’t burn anything at the speed in the downloaded gcode, not even if I slow the speed down from 1500 to 300. In this case O have Lightburn S =255, Gsender $30 =255, $31 = 0 and $32 Enabled. Dip switch 4. G2 lens.
I’ve done a couple of simple text examples that will only get me a result at exceptionally low speeds and the Dip 5 setting.
Thoughts?
Wally??
