Unified, Responsive, and "Zero-Config" Remote Pendant Mode
The Goal:
I would like to suggest a major overhaul of the gSender Pendant functionality to make it a more seamless extension of the desktop software, rather than a separate interface that requires independent configuration.
​Key Improvements:
  1. ​Unified Synchronization: The Pendant should work in perfect sync with the computer instance of gSender. Currently, it feels like a separate connection. It would be ideal if, upon opening the Pendant, it automatically mirrored the active machine state and settings without needing to be “set up” as a secondary device.
  2. ​Full Responsiveness (Tablet-First Design): The interface needs to be optimized for tablets. This includes a layout that adjusts fluidly and correctly to both Vertical (Portrait) and Horizontal (Landscape) orientations. Buttons and readouts should resize to fill the screen effectively, making it a true shop-floor remote.
  3. ​Stability and Ease of Use: The connection should be more robust and “plug-and-play.” The user should be able to simply scan a code or hit a local URL and have a stable, low-latency control surface ready to go instantly.
​Why this matters:
Many of us use tablets at the CNC machine to zero axes and manage jobs. Having a stable, auto-syncing, and responsive UI would significantly improve the workflow and safety, allowing us to focus on the spindle and the material rather than fighting with the interface.
