Using Code for Tool Change
I have code written which allows me to download one file from Aspire and load it into Gsender currently utilizing GSender version 1.17 However, whenever I upgrade the Gsender software and utilize the same code under the “code” section with in Gsender I am unable to get it to work.
I find it odd it works fine in 1.17 but won’t work in any of the newer versions. With that said I am “cheating” the system a bit which may be the reason . When I export out of Aspire I utilize CanCam Masso ATV Arc (inch)(*.nc) as the Post Processor.
I been doing this for over a year now but unfortunately cannot upgrade Gsender or the coding won’t work.
Below is the coding screen shots:
Anyone have any thoughts? Ideas?
Thank you in advance.
Eric
Still looking for feedback if anyone has any? Or anyone from Sienci? Thank you.
There were a few fixes to tool change on the latest version of gSender (v.1.4.8), can you confirm that you are still experiencing this issue on that version?
I will have to redownload and try.
I originally was able to get this working and running properly. Now that I have upgraded to the SLB it no longer likes anything to do with the process I was following before.
@ejbrabender are you still experiencing this issue on the latest version of gSender, v.1.5.7?
