Using F360 with Longmill 30 x 30
hello, I tried to add the Longmill 30 x 30 into Fusion 360 but I’m not sure the download I found was correct because my first test sent the router plunging into my wasteboard. On my next attempt, I used the autodesk generic router xyz and the router cut only 1/8" into the wood.
Anyone have any advice for me? It’d be much appreciated.
thanks
@Zufo First welcome to the forum! Lots of good folks here that can help with a variety of problems. While I don’t use F360, and my experience has not reached expert level yet (if ever), have you zeroed the machine before attempting to carve? The touch plate and zeroing the machine to the work surface is critical to get the machine to cut at the appropriate depth.
I’m sure others will speak up with other solutions for you.
Have fun and be safe!
Jake
Hi Jake and thanks. Yes I should have mentioned that I started each attempt with the touch plate, and I’m using Gsender.
@Zufo I will piggy back on Jake’s welcome. :grinning:
I am only passing familiar with fusion360, but something that causes this when using other CAD/CAM software is that the software setting for Z0 is the machine bed/material bottom and the gSender setting for Z0 is the material surface.
This may not be the cause of your problem, but you may want to start there.
@gwilki that actually sounds like something I need to check out. I also added a 1/2" waste board to the Longmill that f360 has no idea about (because I didn’t account for it).
I was thinking that the touch plate solve this but not the scenario you’re describing. thanks for the idea
@Zufo Adding another layer to the waste board won’t cause you any grief so long as you tell both Fusion and gSender that your Z0 is in the same place. The touch plate can be used to set Z0 on the spoil board. If you want to set all axes using the touch plate, you would set X0Y0 using the plate on the corner of your material, then flip the plate over, put it on the spoil board, and set Z0. Otherwise, set your Z in Fusion on the surface of your material and use the touch plate to set all 3.
I got to say how impressed I am that everything Sienci said about their product has lived up to the promise, including the support network! Thank you. I’m one those guys who tries to learn everything on my own but I am feeling how over my head all this stuff is… but man do I want to learn this like the back of hand.
@gwilki I did not know about the flipping the plate over for the final step. Makes total sense. Thanks again
@Zufo I think that I may have mislead you about using the plate. I’ll try again.
Your original problem could be caused by having your Z0 set differently in Fusioni than where you have Z0 set in gSender. Since you said that you were using the touch plate in gSender, I assumed that you were placing the plate on the left front corner of your material. Doing that, Z0 will be set on the surface of the material in gSender.
So, before going any further in addressing your problem, confirm in Fusion that you are setting Z on the surface of the material. If you are, then your problem is not caused by the “mismatch” and we can move on to other solutions.
I suggest that we forget about flipping the plate over for now until you confirm that Fusion and gS are in sync.
Got it. I will confirm that the two programs are referencing the same Z0 (set Fusion on the surface of the material and use the touch plate to set all 3)
@Zufo It would seem that at least we can see why the Mill is cutting into your spoil board to cut this project. :grinning:
There are people on here that use fusion, so they may have a simple solution. I do not.
While waiting, you may want to post on the Fusion360 forum.
https://forums.autodesk.com/t5/fusion-360/ct-p/1234
Coming back to this after 2 months away. I am sure that the problem is that Fusion 360 and GSender have a different Z0 even though I am choosing the top of the material in F360 and using the touchplate in GSender.
As soon as I start the project, it burrows down through the material into the wasteboard.
I’m using Model box point as the origin
I use the touchplate to do the Z0X0Y0 so not sure where I am going wrong.
(I have sorted out the problem in F360 where the material was buried in the wasteboard so I don’t think that is the issue.)
Hi @Zufo, small question - when you run the Z0 probe cycle, are you probing with the touch block on top of your part, or directly contacting the wasteboard? For the origin you are showing in that image above, you would need to have the probe sitting on top of your stock when you run the probe cycle.
Apologies if I missed a detail in your above thread.
Hi @elbarsal thanks for your question. Yes I am placing the touchplate on the top of the material. After my post I learned about setting up the limit switches and homing my machine in GSender.
Hi @Zufo . Would you be able to post the G-Code here. Also, what is the thickness of the part you are trying to mill?
With the G-Code we should be able to determine if it’s a Fusion 360 problem or a Z0 setup problem on the Longmill/GSender.
@elbarsal Great idea! Here it is
(1002)
(Machine)
( vendor: Autodesk)
( model: Generic 3-axis)
( description: This machine has XYZ axis on the Head)
(T1 D=6.35 CR=0 - ZMIN=-20 - flat end mill)
G90 G94
G17
G21
G28 G91 Z0
G90
(2D Contour6)
T1
S5000 M3
G54
G0 X-157.58 Y-0.635
Z16
G1 Z6 F1000
Z0.635 F333.3
G18 G2 X-156.945 Z0 I0.635 K0 F1000
G1 X-156.31
G17 G3 X-155.675 Y0 I0 J0.635
G2 X155.675 Y0 I155.675 J0
X-155.675 Y0 I-155.675 J0
G3 X-156.31 Y0.635 I-0.635 J0
G1 X-156.945
G18 G3 X-157.58 Z0.635 I0 K0.635
G1 Z16
Y-0.635
Z6
Z-2.565 F333.3
G2 X-156.945 Z-3.2 I0.635 K0 F1000
G1 X-156.31
G1 X-156.945
G18 G3 X-157.58 Z-2.565 I0 K0.635
G1 Z6
Y-0.635
Z1.8 F333.3
Z-6.765
G2 X-156.945 Z-7.4 I0.635 K0 F1000
G1 X-156.31
G1 X-156.945
G18 G3 X-157.58 Z-6.765 I0 K0.635
G1 Z6
Y-0.635
Z-2.4 F333.3
Z-10.965
G2 X-156.945 Z-11.6 I0.635 K0 F1000
G1 X-156.31
G1 X-156.945
G18 G3 X-157.58 Z-10.965 I0 K0.635
G1 Z6
Y-0.635
Z-6.6 F333.3
Z-15.165
G2 X-156.945 Z-15.8 I0.635 K0 F1000
G1 X-156.31
G1 X-156.945
G18 G3 X-157.58 Z-15.165 I0 K0.635
G1 Z6
Y-0.635
Z-10.8 F333.3
Z-19.365
G2 X-156.945 Z-20 I0.635 K0 F1000
G1 X-156.31
G1 X-156.945
G18 G3 X-157.58 Z-19.365 I0 K0.635
G1 Z16
G17
(2D Pocket3)
G0 X0.293 Y2.554
G1 Z16 F1000
Z6
Z4.135 F333.3
X0.268 Y2.57 Z3.943
X0.193 Y2.614 Z3.769
X0.075 Y2.679 Z3.629
X-0.079 Y2.753 Z3.536
X-0.255 Y2.825 Z3.5
G3 X-2.367 Y-2.825 Z3.169 I-1.056 J-2.825
X-0.255 Y2.825 Z2.838 I1.056 J2.825
X-2.367 Y-2.825 Z2.507 I-1.056 J-2.825
X-0.255 Y2.825 Z2.176 I1.056 J2.825
X-2.367 Y-2.825 Z1.845 I-1.056 J-2.825
X-0.255 Y2.825 Z1.515 I1.056 J2.825
X-2.367 Y-2.825 Z1.184 I-1.056 J-2.825
X-0.255 Y2.825 Z0.853 I1.056 J2.825
X-2.367 Y-2.825 Z0.522 I-1.056 J-2.825
X-0.255 Y2.825 Z0.191 I1.056 J2.825
X-2.367 Y-2.825 Z-0.14 I-1.056 J-2.825
X-0.255 Y2.825 Z-0.471 I1.056 J2.825
X-2.367 Y-2.825 Z-0.802 I-1.056 J-2.825
X-0.255 Y2.825 Z-1.133 I1.056 J2.825
X-2.367 Y-2.825 Z-1.464 I-1.056 J-2.825
X1.705 Y0 Z-1.667 I1.056 J2.825
X-1.705 Y0 I-1.705 J0 F1000
X5.515 Y0 I3.61 J0
X-5.515 Y0 I-5.515 J0
X9.325 Y0 I7.42 J0
X-9.325 Y0 I-9.325 J0
X9.325 Y0 I9.325 J0
X8.997 Y0.317 I-0.318 J0
G1 X1.718 Y0.072
X1.653 Y0.067
X1.591 Y0.049
X1.534 Y0.018
X1.164 Y-0.232
G3 X1.519 Y-0.758 I0.178 J-0.263
X1.654 Y-0.554 I-0.178 J0.263
X-4.276 Y0.554 Z-1.998 I-2.965 J0.554 F333.3
X1.654 Y-0.554 Z-2.328 I2.965 J-0.554
X-4.276 Y0.554 Z-2.659 I-2.965 J0.554
X1.654 Y-0.554 Z-2.99 I2.965 J-0.554
X-4.276 Y0.554 Z-3.321 I-2.965 J0.554
X1.654 Y-0.554 Z-3.652 I2.965 J-0.554
X-4.276 Y0.554 Z-3.983 I-2.965 J0.554
X-1.589 Y-3.003 Z-4.158 I2.965 J-0.554
X1.705 Y0 Z-4.333 I0.278 J3.003
X5.515 Y0 I3.61 J0
X9.325 Y0 I7.42 J0
X9.325 Y0 I9.325 J0
G1 X1.718 Y0.072
X1.653 Y0.067
X1.591 Y0.049
X1.534 Y0.018
X1.164 Y-0.232
X-4.276 Y0.554 Z-4.664 I-2.965 J0.554 F333.3
X1.654 Y-0.554 Z-4.995 I2.965 J-0.554
X-4.276 Y0.554 Z-5.326 I-2.965 J0.554
X1.654 Y-0.554 Z-5.657 I2.965 J-0.554
X-4.276 Y0.554 Z-5.988 I-2.965 J0.554
X1.654 Y-0.554 Z-6.319 I2.965 J-0.554
X-4.276 Y0.554 Z-6.65 I-2.965 J0.554
X-1.589 Y-3.003 Z-6.825 I2.965 J-0.554
X1.705 Y0 Z-7 I0.278 J3.003
X5.515 Y0 I3.61 J0
X9.325 Y0 I7.42 J0
X9.325 Y0 I9.325 J0
G1 X1.718 Y0.072
X1.653 Y0.067
X1.591 Y0.049
X1.534 Y0.018
X1.164 Y-0.232
X-4.276 Y0.554 Z-7.331 I-2.965 J0.554 F333.3
X1.654 Y-0.554 Z-7.662 I2.965 J-0.554
X-4.276 Y0.554 Z-7.993 I-2.965 J0.554
X1.654 Y-0.554 Z-8.324 I2.965 J-0.554
X-4.276 Y0.554 Z-8.655 I-2.965 J0.554
X1.654 Y-0.554 Z-8.985 I2.965 J-0.554
X-4.276 Y0.554 Z-9.316 I-2.965 J0.554
X-1.589 Y-3.003 Z-9.491 I2.965 J-0.554
X1.705 Y0 Z-9.667 I0.278 J3.003
X5.515 Y0 I3.61 J0
X9.325 Y0 I7.42 J0
X9.325 Y0 I9.325 J0
G1 X1.718 Y0.072
X1.653 Y0.067
X1.591 Y0.049
X1.534 Y0.018
X1.164 Y-0.232
X-4.276 Y0.554 Z-9.998 I-2.965 J0.554 F333.3
X1.654 Y-0.554 Z-10.328 I2.965 J-0.554
X-4.276 Y0.554 Z-10.659 I-2.965 J0.554
X1.654 Y-0.554 Z-10.99 I2.965 J-0.554
X-4.276 Y0.554 Z-11.321 I-2.965 J0.554
X1.654 Y-0.554 Z-11.652 I2.965 J-0.554
X-4.276 Y0.554 Z-11.983 I-2.965 J0.554
X-1.589 Y-3.003 Z-12.158 I2.965 J-0.554
X1.705 Y0 Z-12.333 I0.278 J3.003
X5.515 Y0 I3.61 J0
X9.325 Y0 I7.42 J0
X9.325 Y0 I9.325 J0
G1 X1.718 Y0.072
X1.653 Y0.067
X1.591 Y0.049
X1.534 Y0.018
X1.164 Y-0.232
X-4.276 Y0.554 Z-12.664 I-2.965 J0.554 F333.3
X1.654 Y-0.554 Z-12.995 I2.965 J-0.554
X-4.276 Y0.554 Z-13.326 I-2.965 J0.554
X1.654 Y-0.554 Z-13.657 I2.965 J-0.554
X-4.276 Y0.554 Z-13.988 I-2.965 J0.554
X1.654 Y-0.554 Z-14.319 I2.965 J-0.554
X-4.276 Y0.554 Z-14.65 I-2.965 J0.554
X-1.589 Y-3.003 Z-14.825 I2.965 J-0.554
X1.705 Y0 Z-15 I0.278 J3.003
X5.515 Y0 I3.61 J0
X9.325 Y0 I7.42 J0
X9.325 Y0 I9.325 J0
G1 X9.317 Y0.098 Z-14.984
X9.295 Y0.193 Z-14.969
X9.262 Y0.275 Z-14.924
X9.218 Y0.352 Z-14.879
X9.176 Y0.408 Z-14.808
X9.128 Y0.459 Z-14.738
X9.059 Y0.517 Z-14.561
X9.033 Y0.534 Z-14.365
Z16
G28 G91 Z0
G90
G28 G91 X0 Y0
G90
M5
M30
Could the issue be this line:
Why is it saying minus 20 in the ZMIN?
Or is it this line down further…
Can you share your actual Fusion project for this?
@elbarsal thank you so much for your help! Here is the link Fusion
From what I can tell from the gcode and the Fusion project (I could only use the web viewer - not sure if it’s possible to easily share the whole project, I could look closer that way) it might be worth it to set up your LongMill as a machine in your library, to ensure everything is correct (instead of the generic 3 axis).
Here is how I have mine set up:
Note that I’m using an adjusted GRBL post processor (you would use grbl). Anything I didn’t screen grab was left as defaults. It’s also important that the tree under Kinematics (X Y Z) are nested as shown.
I think you’re close, it’s just hard to sort the details when there are a number of things to check!
Thank you again for taking time out to help me. I will check all of these settings and also learn about sharing the full project. I will take care of this asap and get back to you.
