Using F360 with Longmill 30 x 30
Hi @Zufo .
I’m no expert on this – as a matter of fact my Longmill MkII is supposed to arrive later today so I don’t have any direct experience with it – but I think the issue may be this command in the 4th line of the G-Code:
G28 G91 Z0
That is a homing command which should send the router to “machine home” not the workspace home where you’ve zeroed the XYZ positions. Unless you have inductive sensors, to home the machine at each startup, I believe machine home is set to wherever XYZ is when the machine is powered on/reset (unless it’s has been set with a G28.1 command).
In Fusion 360 there used to be a setting in the post processor setup that allowed you to turn on and off G28 Safe Retracts
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-disable-G28-in-GBRL-post-processor-Fusion-360-HSM.html
but I believe that dialog box has changed now and you can now only select between G28, G53 or Clearance Height safe retracts. The Clearance Height setting seems to make the most sense in this case since it’s based off the workspace zero.
I hope to have some actual experience with the Longmill in the next week or two so if this is all off base, my apologies. Hopefully someone else can chime in with more certainty.
@Diesel that’s some pretty insightful help from someone who’s yet to receive their machine! It definitely feels like it’s relevant to what I’ve been experiencing. I will add this to what I’ve received so far for my weekend foray. I will update this log tomorrow. Cheers
I had the spindle below the table in the Kinematics tab. But it is now set up correctly.
I’ve created a new project and here is the code
(disk-w-hole)
(Machine)
( vendor: Scienci)
( model: 30 x 30 Mk 1)
( description: Longmill Mk 1)
(T1 D=6.35 CR=0 - ZMIN=-21 - flat end mill)
G90 G94
G17
G21
G28 G91 Z0
G90
(2D Contour4)
T1
S5000 M3
G54
G0 X-4.08 Y152.865
Z15
G1 Z5 F1000
Z2 F333.3
Z-0.365
G18 G2 X-3.445 Z-1 I0.635 K0 F1000
G1 X-2.81
G17 G3 X-2.175 Y153.5 I0 J0.635
G2 X309.175 Y153.5 I155.675 J0
X-2.175 Y153.5 I-155.675 J0
G3 X-2.81 Y154.135 I-0.635 J0
G1 X-3.445
G18 G3 X-4.08 Z-0.365 I0 K0.635
G1 Z5
Y152.865
Z1 F333.3
Z-1.365
G2 X-3.445 Z-2 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-1.365 I0 K0.635
G1 Z5
Y152.865
Z0 F333.3
Z-2.365
G2 X-3.445 Z-3 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-2.365 I0 K0.635
G1 Z5
Y152.865
Z-1 F333.3
Z-3.365
G2 X-3.445 Z-4 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-3.365 I0 K0.635
G1 Z5
Y152.865
Z-2 F333.3
Z-4.365
G2 X-3.445 Z-5 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-4.365 I0 K0.635
G1 Z5
Y152.865
Z-3 F333.3
Z-5.365
G2 X-3.445 Z-6 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-5.365 I0 K0.635
G1 Z5
Y152.865
Z-4 F333.3
Z-6.365
G2 X-3.445 Z-7 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-6.365 I0 K0.635
G1 Z5
Y152.865
Z-5 F333.3
Z-7.365
G2 X-3.445 Z-8 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-7.365 I0 K0.635
G1 Z5
Y152.865
Z-6 F333.3
Z-8.365
G2 X-3.445 Z-9 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-8.365 I0 K0.635
G1 Z5
Y152.865
Z-7 F333.3
Z-9.365
G2 X-3.445 Z-10 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-9.365 I0 K0.635
G1 Z5
Y152.865
Z-8 F333.3
Z-10.365
G2 X-3.445 Z-11 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-10.365 I0 K0.635
G1 Z5
Y152.865
Z-9 F333.3
Z-11.365
G2 X-3.445 Z-12 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-11.365 I0 K0.635
G1 Z5
Y152.865
Z-10 F333.3
Z-12.365
G2 X-3.445 Z-13 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-12.365 I0 K0.635
G1 Z5
Y152.865
Z-11 F333.3
Z-13.365
G2 X-3.445 Z-14 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-13.365 I0 K0.635
G1 Z5
Y152.865
Z-12 F333.3
Z-14.365
G2 X-3.445 Z-15 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-14.365 I0 K0.635
G1 Z5
Y152.865
Z-13 F333.3
Z-15.365
G2 X-3.445 Z-16 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-15.365 I0 K0.635
G1 Z5
Y152.865
Z-14 F333.3
Z-16.365
G2 X-3.445 Z-17 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-16.365 I0 K0.635
G1 Z5
Y152.865
Z-15 F333.3
Z-17.365
G2 X-3.445 Z-18 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-17.365 I0 K0.635
G1 Z5
Y152.865
Z-16 F333.3
Z-18.365
G2 X-3.445 Z-19 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-18.365 I0 K0.635
G1 Z5
Y152.865
Z-17 F333.3
Z-19.365
G2 X-3.445 Z-20 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-19.365 I0 K0.635
G1 Z5
Y152.865
Z-18 F333.3
Z-20.365
G2 X-3.445 Z-21 I0.635 K0 F1000
G1 X-2.81
G1 X-3.445
G18 G3 X-4.08 Z-20.365 I0 K0.635
G1 Z15
G17
(2D Pocket2)
G0 X151.242 Y150.517
G1 Z15 F1000
Z5
Z3.135 F333.3
X151.271 Y150.513 Z2.943
X151.357 Y150.502 Z2.769
X151.491 Y150.49 Z2.629
X151.662 Y150.484 Z2.536
X151.853 Y150.488 Z2.5
G3 X151.525 Y156.512 Z2.169 I-0.164 J3.012
X151.853 Y150.488 Z1.838 I0.164 J-3.012
X151.525 Y156.512 Z1.507 I-0.164 J3.012
X151.853 Y150.488 Z1.176 I0.164 J-3.012
X151.525 Y156.512 Z0.845 I-0.164 J3.012
X151.853 Y150.488 Z0.515 I0.164 J-3.012
X151.525 Y156.512 Z0.184 I-0.164 J3.012
X151.853 Y150.488 Z-0.147 I0.164 J-3.012
X151.525 Y156.512 Z-0.478 I-0.164 J3.012
X151.853 Y150.488 Z-0.809 I0.164 J-3.012
X154.705 Y153.5 Z-0.969 I-0.164 J3.012
X152.295 Y153.5 I-1.205 J0 F1000
X158.515 Y153.5 I3.11 J0
X148.485 Y153.5 I-5.015 J0
X162.325 Y153.5 I6.92 J0
X144.675 Y153.5 I-8.825 J0
X162.325 Y153.5 I8.825 J0
X161.994 Y153.817 I-0.317 J0
G1 X155.494 Y153.545
X149.043 Y153.208
G3 X148.75 Y152.82 I0.017 J-0.317
X154.627 Y154.18 Z-1.3 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-1.631 I-2.939 J-0.68
X154.705 Y153.5 Z-1.938 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-2.268 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-2.599 I-2.939 J-0.68
X154.705 Y153.5 Z-2.906 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-3.237 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-3.568 I-2.939 J-0.68
X154.705 Y153.5 Z-3.875 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-4.206 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-4.537 I-2.939 J-0.68
X154.705 Y153.5 Z-4.844 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-5.175 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-5.506 I-2.939 J-0.68
X154.705 Y153.5 Z-5.813 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-6.143 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-6.474 I-2.939 J-0.68
X154.705 Y153.5 Z-6.781 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-7.112 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-7.443 I-2.939 J-0.68
X154.705 Y153.5 Z-7.75 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-8.081 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-8.412 I-2.939 J-0.68
X154.705 Y153.5 Z-8.719 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-9.05 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-9.381 I-2.939 J-0.68
X154.705 Y153.5 Z-9.688 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-10.018 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-10.349 I-2.939 J-0.68
X154.705 Y153.5 Z-10.656 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-10.987 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-11.318 I-2.939 J-0.68
X154.705 Y153.5 Z-11.625 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-11.956 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-12.287 I-2.939 J-0.68
X154.705 Y153.5 Z-12.594 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-12.925 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-13.256 I-2.939 J-0.68
X154.705 Y153.5 Z-13.563 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-13.893 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-14.224 I-2.939 J-0.68
X154.705 Y153.5 Z-14.531 I2.939 J0.68
X149.043 Y153.208
X154.627 Y154.18 Z-14.862 I2.939 J0.68 F333.3
X148.75 Y152.82 Z-15.193 I-2.939 J-0.68
X154.705 Y153.5 Z-15.5 I2.939 J0.68
G1 X162.317 Y153.598 Z-15.484
X162.295 Y153.693 Z-15.469
X162.262 Y153.775 Z-15.424
X162.218 Y153.852 Z-15.379
X162.176 Y153.908 Z-15.308
X162.128 Y153.959 Z-15.238
X162.059 Y154.017 Z-15.061
X162.033 Y154.034 Z-14.865
Z15
G28 G91 Z0
G90
G28 G91 X0 Y0
G90
M5
M30
@Diesel - I’ve created a new project and will try it with my machine properly ‘homed’. I do have inductive sensors and I’ve run the homing cycle. Will now attempt the new project.
PROBLEM SOLVED!
Homing was key. And so was having the machine Kinematics set up as: X Linear > Y Linear > Z Linear > Spindle > then Table at the end. I had Table and Spindle reversed before.
I am so happy to finally be able to start using this thing. Good to know I learned so much along the way.
Thank you everyone for the help you’ve provided!
Excellent, looking forward to seeing your creations!
@Zufo Thanks to the excellent advice you received, Hannu, and your persistence, it looks like your issue is resolved and that you are well on the way to having fun with your Mill.
As your issues seem to be resolved, I’m closing this thread. Anyone having similar issues should open a new thread so that your individual details can be addressed.
