Vectric on Linux, goodbye and good riddance Windows
I’ve been using Windows since I got my LongMill because of wanting to use VCarve and not wanting to reboot every time I had an idea and needed VCarve. The whole time I’ve been trying to get Windows to act more like Linux especially on the command line with some success but it’s never been ideal for me.
I get so sick of Windows pushing me to sign in with a Microsoft account and other silly BS. So I decided to see if I could go the other way and run Vectric on Linux. It turned out to be pretty easy. It runs fine under WINE with it set to Windows 10 32-bit. So now I’m running Gentoo on my development/design PC and Pop!_OS on my laptop that controls the LongMill. Pop!_OS is in the Debian/Ubuntu family and the gSender ‘deb’ package installed and is working fine. So is LightBurn on Pop!_OS.
I no longer have Windows installed on anything and I am so happy to have that Microsoft monkey of my back!
Nice! I didn’t really think about using Linux on the PC that controls my LongMill, but I can definitely see there being benefits there.
Do you see much of a difference in gSender on Linux? I have an older workstation class box (it was free) for that machine - plenty of horsepower for either OS, might try a dual boot to check it out.
I just got Pop!_OS, LightBurn and gSender setup today so I haven’t had much of chance to play with it yet. There is a significant improvement in the startup time for gSender, I can tell you that much already.
I focused on getting Vectric working first. Verifying that it worked by making a test file and running it with gSender on Windows to make sure that Vectric was working okay under WINE. Then I swapped the control PC over today, so far all is good. Next I need to setup NFS for sharing files between them. Having Gentoo in the mix without a full desktop package is slowing me down a bit but I like setting everything up just so on my dev/design machine. I took the easy route with the laptop though.
I am trying to get VCarve Pro to run in Debian using Wine or Bottles and I keep getting a crash. Any chance you could help me out?
I didn’t do anything special to get it ‘working’ besides setting Wine to Windows 10, 32-bit. I’m not very experienced with Wine so I used Q4Wine to set it up. It seemed to work, so I excitedly posted about it, but then I found some problems. I should have updated this thread but it was depressing :frowning: and then I forgot. The layers in VCarve Desktop didn’t work and the tool path previews were messed up graphically. It made me question whether the tool paths would be reliable. I was/am using version 11.5 of Vectric, license expired for upgrades, so that might be a factor if your on 12.
I ended up dual booting Windows to use Vectric and now I’m wondering if I can make what I want to make without Vectric so I can ditch Windows for good. I have a list of software that I need to check out but if you just shelled out $600 U.S. for VCarve I’m guessing you want to use it.
I’ve been using VCarve Pro on Windows for a while now. Building a new PC and figuring it will be much faster and less expensive to run Debian instead of windows. Testing the theory in a VM and an old laptop before committing. I keep running into a kerberos (windows auth) issue that I haven’t been able to find a way around. I will reach out in the wine communities.
A note for your issue, according to WineHQ you need to install the dll “comctl32” and “vcrun2019” to fix the layers and rendering.
I like vcarve for its simplicity but I have made some cool things in freeCAD. You just have to take the time to learn it but theres a really good youtube basics video by Novaspirit Tech and a lot of other tutorials.
Thanks for the info.
Thanks for the info on those DLL’s, maybe I’ll give it another shot. I have used FreeCAD before but I’m thinking that doing a v-carve in it would be difficult unless I’m missing something. The programs that I’m most interested in checking out now are f-engrave, heeksCAD/heeksCNC and the BlenderCAM addon for Blender.
As to your issue, I was not working in a VM, so maybe that’s the difference. I don’t know about Kerberos but I thought is was a only on Window’s server. The other possibility I thought of was Debian’s software tends to be older but very stable, but I wouldn’t think that jives with Kerberos being the issue.
Thanks again Ronnie!
P.S. If you end up staying with Windows I got my last copy from kinguin for cheap and never had any issues with it. It was Windows 7 Pro and it upgraded to 10 for free when 10 released.
I used f-engrave when I first started out on the cnc. It was good but I would occasionally run into an issue where it would just decide my vcarve needed a hole drilled all the way through it for no reason at all in a place there were no vectors. It was on an old windows 7 laptop so not sure if it was a compatibility glitch or software or what.
Tried wine on physical hardware too and had the same kerberos issue. Going to try to run through it again tonight and throw the terminal output into the wine subreddit. Hopefully its something dumb easy and one of those guys knows what to do.
Thank you for the windows key advice!
Probably don’t need to add this for this particular post. But I’ll add it anyway.
Usual preface, I’m with PreciseBits. So while I try to only post general information take everything I say with the understanding that I have a bias.
I never ran into any of these issue the last time I ran Aspire under Wine. I did run with the dlls per the WineHQ result for Vcarve (Link). I believe it was version 12. All I did was see if it worked, opened a file and ran a preview though. I still have a lot of software that I have to run in windows so I already dual boot.
One thing that might make a difference is that setup also runs DXVK as (back when I had the time) I would game on it. In that same strain that system ran with a 3090. So there might be a link somewhere with the proprietary drivers or hardware too. In theory it shouldn’t matter as long as there’s 2gb of vRAM since the system requirements note OpenGL. Seen stranger things work though.
The Aspire result on WineHQ (Link) also was running DXVK and had some similar/different issues. However, they didn’t note installing the dlls. Maybe there’s a combination there that works? Although, they are also different versions, different drivers, and card brands. So that might be related.
If I ever get some time I’ll try it again. This is actually the 4th time it’s come up for me in the last few months.
I’ve also used Kinguin and haven’t had issues. Make sure that if you don’t want to be on a phone loop that you get the online activation versions though.
My understanding is the latest version of VcarvePro went 64 bit. If correct it will no longer run under WINE win32.
@LewisB314 I believe that you may be confusing VCarve and gSender. The Vectric site still shows a 32 bit processor as acceptable. However, gSender has been only 64 bit for quite a while now.
Yeah, i think you correct. I was at work and relying a vague memory of what i read a while back. Thanks for the clarification.
It’s been almost a year since we’ve heard anything on this thread. My Altmill is supposed to arrive Monday and I’m really hoping to avoid Windows. Has anyone had success with a recent version of VCarve running under Wine?
Hello Bob, welcome to the group!
I have not. Between my license not getting updates anymore and my disdain for Windows I’ve stopped using it.
I’m in the process of learning FreeCAD now. I just looked at your profile and I see you’ve been using Blender. I think Blender is an amazing program but I had some problems figuring out the BlenderCAM and CADSketcher addons. To be fair it’s been awhile since I played with Blender so that didn’t help.
It’s still early days with FreeCAD, at least with the CAM workbench, for me. I’ve used it some in the past for designing things to 3D print. I haven’t done anything major yet with FreeCAD but I have done some test carves and some laser engraving with it. I’ll get there, I hope!
Good luck with whatever path you take going forward. You must be stoked with your AltMill coming soon!
Yesterday I designed my spoilboard in vcarve. Only took about 20 minutes. Tried to do the same in FreeCAD and spent most of the day and still did not have what I wanted. The problem is VCarve just seems so easy to use. I might just have to fork out the bucks!
It’s hard to disagree with that statement. I keep telling myself that part of it is because I used VCarve for 3 or 4 years and I don’t really remember how easy or hard it was when I started. That said, FreeCAD does go about things very differently IMO.
For example I was thinking about making some dog holes in my spoilboard and the way I ended up doing fit test pockets was by making the pocket in the stock, in 3D, and then selecting the walls of the pocket to make the toolpath. I’m not sure if that is the only way to do it though. I’m thinking that for basing toolpaths from 2D lines the lines might need to be made in the Draft workbench and not from a Sketch. I was able to V-carve some text that was made in the Draft bench but I just tried to test a V-carve inlay the other day and I made the design in a Sketch and I couldn’t figure it out. I quit without even saving because I got so frustrated!
I’m not running a business or anything so I’m not under any time crunch. If I was I’d probably have gone back already to VCarve already.
Well half of my AltMill order arrived yesterday. The gControl was among what arrived. I went ahead and bought VCarve and installed it on the gControl. The gControl had RustDesk installed, so I installed that on my Linux box too. Now I’m running VCarve on the gControl, but running it remotely from my Linux box. Seems a reasonable solution for now.
Just thought I’d give an update on my current VCarve use on Linux. VCarve has proven difficult for me to give up. It’s just too good and I try to remain ignorant of new features so I don’t feel left behind running 11.5.
On the Linux part I currently have it installed through Lutris using wine-staging-10.x 64 bit. It had been awhile since I tried Lutris and I think it’s much improved. I didn’t have to do anything special for Wine settings in Lutris but the last time I checked it only worked with wine-staging.
Lutris made getting VCarve running well on my Gentoo Linux system easy. My PC is a system I put together in 2016. It was fairly high end at the time with a Core i7 6600k, GTX 1070 and custom open loop liquid cooling. It still purrs like a kitten but I would really like to play with real time ray tracing someday…
I just wanted to add to this to confirm for others that it works. I have been fighting to get Aspire working in linux and closest I have come so far is a virtual machine in vmware, which still involves Windows [shakes fist at sky].
I got it running today based on what _Michael posted. Installed in Lutrix under Win10-64, running the wine-staging 11 (latest version of lutrix doesn’t have 10.x anymore) after installing wine-staging for the whole system as listed below
sudo dpkg --add-architecture i386
wget -O - https://dl.winehq.org/wine-builds/winehq.key | sudo gpg --dearmor -o /etc/apt/keyrings/winehq-archive.key
sudo wget -NP /etc/apt/sources.list.d/ https://dl.winehq.org/wine-builds/ubuntu/dists/noble/winehq-noble.sources
sudo apt update
sudo apt install --install-recommends winehq-staging
Everything I have tested so far works, including 3D preview which actually is more responsive than when run in the VM.
On my 2014 Acer, i5-5200U processor, upgraded to the max of 12G ram and replaced the HD with a SSD. Latest release of Linux Mint, using Bottles, VcarvePro works prefect (as far as i can tell)
My Bottle settings are win32, sys-wine-10.0 DXVK.
It runs Fast on this old laptop.
