Yes, that works. No text description visible but fairly obvious what the three areas are. That is very helpful, thanks!
@chrismakesstuff Chris: I have no interest in setting my Mill up to work vertically, but I watched this video in its entirety. I believe that this is your best video yet in terms of explaining the design/cam/cutting process. I donāt use CamLabs, but I would recommend that anyone starting out in CamLabs watch this video for a quick tutorial on its setup. The only criticism that I can offer is that it was unclear how you changed the orientation from Z0 being in the centre for design purposes, to using the plate to set it to the lower left corner, then moving it back again before cutting.
ps. Love the carving.
Yeah, I think it was a bit unclear too. Thanks for the feedback Grant, I actually got to thinking that it might make more sense to try splitting the video up into two separate ones, one on the vertical setup and another on the CAMLab carving, so Iāll be experimenting to see if I can do that tonight with the existing footage
Good morning, I purchased the longmill MK2 48x30 a few weeks ago and it has been working great; i changed to a vertical wall mount to save floor space and the gantry slides towards the floor (Y-) assuming due to the weight and gravity. is there an adjustment i missed during the assembly?
Gāday Alan, if you donāt have any counterweight system set up, then youāll need to go to the firmware tool and update the value for $1 to equal 255. This will keep your motors always engaged so that the Y-axis shouldnāt fall over time
This will tend to make the motor drivers run hotter, so just be mindful of that ![]()
Thank you Chris, that firm ware worked. can you recommend a counter wight system?
A post was split to a new topic: Vertical setup - Y axis drift
