View stock outline in visualizer
I would like to suggest a feature in gSender where you could load a 3D model of the stock that your job will use and show it on the visualizer along with the NC file. Could be an upload of an STL or STEP file and a prompt for Z rotation and X/Y origin placement along with an option to create a cylinder or cube where you enter the appropriate dimensions and the X/Y origin. Visually this could be a translucent grey shaded representation of the stock.
This would be a useful feature along with the ability to configure keep-out zones in gSender. Perhaps both the stock size and the keep out zones can be set by jogging to the location and recording the current coordinates.
You can configure keep out zones in vCarve, but sometimes I don’t know where they will be located until I put my stock in the machine. Also , the stock I use is rarely the same size as what I configured in cam. It’s the correct thickness but width and depth is usually bigger.
Also, the keep out zone in vCarve are not respected at the end of the job. So having it in gSender could help.
