Before a project I jog the x-axis to the back and ensure it is aligned with both y-axises. After a project when I jog the machine back, i notice that the left x-axis gantry touches the left y-axis before the right side does. I would it’s about 1/8 to 3/16 off everytime.
Is this normal? Do i need to reset before each project?
@DRIZZY No, it’s not normal. Check the wires going to both Y motors. Check that your delrin wheels are set properly. Finally, check that the anti-backlash nuts are set properly.
@DRIZZY Back them off completely. You should get a bit of back and forth movement in the direction of the axis. Then tighten in VERY small increments, testing for movement. As soon as you detect no movement, that’s it. Do not tighten them any further.
