Xyz probe touchplate adaptation
Silly question, but have to ask. gSender is capable of XYZ zeroing. The Fox Alien Masuter Pro comes with just a Z0 touchplate. Since it’s a single wire connection, same as the XYZ touchplate, can I adapt the XYZ touchplate to the Fox Alien controller? I know the plug will need to be changed, but I’m not sure if the machine controller has anything to do with probing. Fox Alien says they only offer the Z touchplate, but they didn’t say whether an XYZ toouchplate would work. BTW…I just ordered the Nema 23 upgrade, and that comes with a new controller, but they say they only offer a Z0 touchplate to hook up to the controller. Thanks.
i’m using a 3d touch probe, the mini chinese one, it has 3 wires V+ Ground and signal, so for me i can say it’s 1 wire probe, so yes GSender definitely can do XYZ probing
btw, i have a diy cnc but i should not matter what you use
also the probe triggers a relay that has 2 wires hooked to the 2 pins for probing on the controller board
