Z axis limit sensor wont thread
I’m assembling the z-axis, and the limit sensor hole is too small. It just barely starts to thread, then stops. Wondering if I should chase the threads/retap?
@ArmyDoc I suggest that you contact Sienci support.
I have sent in a ticket on the web page.
OK, so apparently it is pretty common to be hard to start. The hole is tight at the mouth and the sensor is fairly slick / difficult to get a grip on. What I did is put two of the nuts half way up the threaded barrel of the sensor and lock them together. Then I pushed down firmly while screwing them in. The locked nuts gave me enough grip to get it started. Then I used their multi tool to turn the back nut which screwed the sensor in. Once it is in a turn or two, it becomes easy to thread it in with just your fingers.
