Brand new Altmill 4x4
Z axis don’t work. Shows moving on computer.
Switch out Z and X cables everything works.
Switch it back to original Z axis don’t work, XY work fine
switched cables at Z and X at the motors only and everything works.
limits sensors are checked and working.
Check everything on computer and don’t really know what to look for or change. I did disable the soft and hard limits and it didn’t change anything.
anyone have the same issue?
@StanleyP I’d check the pins on the connectors to make sure one of them is not bent.
When you say, you swap out the x and z cables and both work, are you changing them at both ends?
All pins are good. No broken wire, check continuity.
Yes, switch Z and X cables. Controller and motor.
And the Z and X works.
@StanleyP Well that’s weird. Looks like you tried everything. Best way to troubleshoot is repeatability. So I’d swap the cables a second time to see if they still work.
Since it all works if I switch cables. Could I just switch the motors? What would that do? They have different dip switches
@StanleyP The Z motor is different from the other 3.
@StanleyP If simply swapping the X and Z cables results in all four motors to work, I’d suggest opening a ticket with Sienci. The cables are likely not the right length so you can’t keep them swapped, right ?
This is just the Z and X. If I swap the z and x the motors work. Cables will not work. So I thought since swapping cables work I’ll just swap the motors and see.
