I am using the Shapeoko BitZero on a Shapeoko CNC.
Problem:
When I set the XYZ with the prob, then check the Z 0 setting it is low by 1/4 inches and the Z goes up and hits he mount.
If I just set the Z with the prob everything is fine, check the Z 0 and it is spot on. Z goes up to the same spot as when it is Homed.
Gsender 1.1.4
New to Gsender and I am sure I am doing something wrong, thanks for any help.
I measured the block with good digtal calipers and entered it in the prob settings.
My work around is do the XY and the do the Z. This works fine but it should work with the ZXY.
@Bill-Tx Can you post the settings and the log for the XYZ probe here? I think something is off.
Specifically, this. @KGN Why 3x retract+ probe thickness here?
The prob settings are: Z Thickness .867, XY Thickness .278, Length 2.363, Width 2.363.
The stock is .748.
client $H
ok
client $J=G20G91 X-1250 Y-1250 F118.11
ok
client \x85
feeder G10 L20 P1 X0 Y0 Z0
ok
feeder G91 G20
ok
feeder G38.2 Z-1.2 F5.9
[PRB:-294.325,-294.325,-17.290:1]
ok
feeder G91
ok
feeder G0 Z0.15
ok
feeder G38.2 Z-1.2 F2.95
[PRB:-294.325,-294.325,-17.270:1]
ok
feeder G10 L20 P1 Z0.867
ok
feeder G91
ok
feeder G0 Z0.15
ok
feeder G0 X-0.797
ok
feeder G0 Z-0.591
ok
feeder G38.2 X2 F5.9
[PRB:-310.125,-294.325,-28.530:1]
ok
feeder G91
ok
feeder G0 X-0.15
ok
feeder G38.2 X2 F2.95
[PRB:-310.325,-294.325,-28.530:1]
ok
feeder G4 P0.3
ok
feeder G91
ok
feeder G10 L20 P1 X-0.403
ok
feeder G0 X-0.3
ok
feeder G0 Y-0.797
ok
feeder G0 X0.797
ok
feeder G38.2 Y2 F5.9
[PRB:-297.525,-301.975,-28.530:1]
ok
feeder G91
ok
feeder G0 Y-0.15
ok
feeder G38.2 Y2 F2.95
[PRB:-297.525,-301.875,-28.530:1]
ok
feeder G4 P0.3
ok
feeder G91
ok
feeder G10 L20 P1 Y-0.403
ok
feeder G0 Y-0.15
ok
feeder G0 Z1.317
ok
feeder G0 Y0.728
ok
feeder G90
ok
