I donāt know if anyone else has this problem in gSender, but still after months of use I often hit Set to Zero instead of GoTo Zero, which messes up my workflow. I use GoTo more than SetTo, but SetTo is more prominent and has no undo. It would be nice if there was a graceful way to backtrack or to have SetTo require a confirmation. @KGN
I agree, I find myself pausing to think about which to click on, so I donāt screw it up again. The one that still gets me is when I have multiple paths for the same project, and I programmed P2 for the job, the software defaults to P1 after every path is completed.
Iāve had a rant about that before version 1 came out. They said it is common everywhere else. I donāt care about everywhere else.
So, I started taking advantage of that with my default setup, but I still have P2-P6 programmed all over my spoilboard for smaller projects, too. Every time I HOME, I run a macro that initializes the default XYZ zeros for P1-P6.
I, too, am very slow to decide what to click here.
What do you mean by " I run a macro that initializes the default XYZ"? I have not worked with macros, donāt really know what that is. Thanks
Hey folks, a couple things to address here,
1) RE āSetā being more prominent than "Go to"
Weāll continue to collect feedback about this, but for the time being weāre going to leave it as it is. Way back in the early releases, we actually had these swapped (ie Go To was the bigger button, Set was the smaller one) and the most common piece of feedback we received was that this was backwards and we reversed them. Itās clearly something that maybe a little more subjective as to what the most important/common action to take is (do you set zero more than go to? Do you jog over using Go To? etc).
It might just be that this area as a whole needs a redesign in terms of visual clarity if people are āslow to decide what to clickā or consistently press the wrong action. Weāve tried to stay consistent with the colour scheme of āsolid blue results in the machine movingā throughout the main UI as a secondary indicator of what each button does, but maybe that doesnāt work in this case.
We also might just end up adding a preference for button order, but I think some redesign might be likely since weāve had this conversation before internally about the design of that widget. For the time being, however, weāre going to leave the functionality where it is to prevent confusion for the greater number of users.
2) "Software defaults to P1 after every path is completed"
This statement doesnāt 100% track with implementation and Iām going to ask you to follow up on some things here.
āStoppingā a job (with the red stop button) issues a board reset command which results in all modals going back to default (including G54/P1). In the next release, if you stop a job, after the reset it will return you to whatever WCS you were in previously (so if you ran a job in G56 and stopped it using the red button, after the reset gSender will issue a G56 command to get you back into the previous WCS). Weāve had a change of opinion after internal discussions on this and want to remove this as a possible pain point for users who do use different WCS.
āJob completingā (a file runs through to the end) does not reset the board, so your WCS should not change, which is leading to my confusion - I can run multiple jobs in a row in whatever WCS I want and donāt see my WCS changing on Pgm End. Nothing in the codebase resets WCS by itself - relevant events and code below. The gist is that when the Sender determines the program is finished, it emits an āendā Event. The controller, on receiving an āendā event, sets the finishTime, and eventually sends a āstopā command to rewind the program. At no point is the board reset or modals changed.
What may be happening is that you have some code in your āProgram Stopā event in settings that is changing modals/WCS, since that code is run a) if you stop using the button as well as b) the program ends naturally. If this is not the case, could you send a video/screenshot of your console output when a toolpath completes so I can have a better idea of whatās going on for you - we canāt recreate it on our end.
Cheers,
Kevin
for zeroing what about a confirmation dialog like there is when you close a gCode file? That would solve my problem by alerting me that I am making this change @KGN
This is also an option weāre considering, but are trying to avoid adding more āclicksā for common actions as a general usability rule.
Kevin
I would say that the confirmation dialog for closing a file is less useful: the point is that it is an action that is easily recovered from, whereas the change of zero is not. Such confirmations could be a preference, though that adds a different form of complexity
Well, Iāll be a durned horned frog! Thatās what Iāve been waiting for, and Iāll still be looking for it.
Now if you can just get Z to raise to a safe height after a āSTOPā ā¦
Just to follow up on āWorkspace resets on program completeā:
After some back and forth, we found that those reporting their WCS is reset after a program completes was due to having a M2 command (program stop) at the end of their gcode program.
M2 resets GRBL to default state, including WCS.
Potential workarounds/solutions are as follows:
Make sure your program doesnāt contain M2/M30 that would reset GRBL wcs to default, or any G54-59 commands that would change workspace
You can use the start and stop gcode blocks to store and restore your WCS at the start/end of each program.
%global.state.workspace=modal.wcs
in the start section will store your current WCS in the workspace variable
[global.state.workspace]
in the stop section will issue the WCS command to restore the workspace after the program ends (if you do have M2 that you donāt want to remove).
This + the change for the stop button itself restoring WCS should cover all situations where people were reporting WCS changing on them.
Cheers,
Kevin
I know this topic was mentioned back on April 22, but that discussion is closed. I recently switched to Gsender 1.1.7 on my Homebuilt CNC. Very happy. My only real problem is the go to zero and setzero buttons are too similar, and several times I have messed up coordinated that I set up manually by accidentally hitting set zero instead of go to zero. I think it would be very helpful if the goto and set0 buttons were a different shape or color from one another. Another option would be to have a āundo ābutton that you could click to undo a previous jog or zero command. This button could be on the main screen, or even in a drop-down under set up or something. I understand it would be a hassle to have a āclick to confirm your choiceā window or button every time you did a command, so I am not asking for that, but possibly undo button. Or, if you didnāt actually want to build a button on the interface, a keyboard shortcut command that you could hit, for example, control C, to undo the previous command.
did this a lot, until I got paranoid of those buttons
I like the control Z option???
Ya, I use carbide create to design my cuts and in that program control z is the undo command and I find it helpful.
I vote for a longpress required for set zero button, this way an accidental click/tap wont do anything.
A safety backup in the mean time might be to set the same zeros in another workspace, G55, at the beginning of the project when the same zeros are set for G54. If zeros are overwritten in G54, user can switch workspace to G55, select goto zero, switch back to G54 and save those zeros.
Once you get comfortable with a program, none of this will be important. Get some mileage with it, it will be just fine and you wonāt want to change anything.
One of the things I sometimes do which may mitigate this, is to set the zero in two workspaces. So if you mess up one you have the backup values in another workspace.
Next release will have an opt-in setting that forces a confirm on zero - itās off by default but will guarantee you donāt zero when you donāt mean to if you prefer that option.
Weāre going to re-evaluate the DRO area design in general sometime in the near future to move the buttons further apart. This will likely come with the official 4-axis support version.
This was implemented! You can find it under Settings ā Safety ā Warn on Zero, where turning it on will make it so clicking to zero warns you before doing it so you donāt accidentally misclick
As Kevin said, weāre also aiming to redesign the UI which weāre working on right now to hopefully eliminate accidental zeroing . Thanks yāall for your feedback ![]()
