1.4.12 problems
Just loaded 1.4.12 update. Gcode that ran perfectly yesterday now has lots of pauses in it, inaccurate z positioning, and finally just stops in the middle of the job. ‘Verify Job’ doesn’t run through either. Tried redownloading 1.4.12 - no help. Recalculated gcode. No help. Anybody else having problems after getting 1.4.12?
Yes. Having similar problem after loading 1.4.12 update. My “z” now cuts .8 of an inch above the project after setting zero with touch plate.
gSender versions from 1.5.0 and above include the redesigned UI, along with several major bug fixes, including ones from 1.4.12. Have either of you had a chance to try the latest version of gSender? If so, are you still experiencing these bugs?
