1.5.6 Fixed Sensor Tool Change Problem
Shapeoko 4
Bitsetter II
Windows 11
Gsender 1.5.6
Set XY at tool sensor, Z .75 above it.
Run small program with a tool change.
Runs to tool change, moves to sensor and runs tool change wizard.
Click button to probe initial tool.
Z moves dow quickly to set height, then slows.
Z moves down, pushes sensor down, LED lights and Z keeps moving down until it bottoms out.
Have used Carbide Motion to verify that control board sees the open/closed of the sensor.
Solved. Requires “T1 M6” at start of gcode.
