$395 Default Spindle
I am installing a PWNCNC spindle and I am unable to find $395 Default Spindle in the firmware. I am using a Longboard on a MK2 30 X 30 with gSender 1.4.11
How can I access $395?
I put the PWN spindle on my MK1, and I could not find $395 either, so I just egnord it. Works just fine. Just my $.02 worth.
I have enabled everything in the firmware but cannot get my spindle to turn on.
Had the same problem, until I hit the green button on the vfd. Simple, and I felt like a dumb a** after that. :grin: Also had to turn on the power switch located by the power cord (bad place to put that), Tell gsender you are using a spindle also in the setup.
Guess I am also a dumb a**. Didn’t think you had to hit the green run button since it is in auto mode. This fixed my issue. Thanks
Glad you got it going. Now to have fun making wood chips. :grinning:
