Alarm 10 triggered during long carves
After upgrading to gsender 1.6.3 I have been getting alarm 10 problems. During long carves I’ve gotten an alarm 10 triggered a couple times. No one has been in the shop with me and both times I have been across the shop so the stop was not pushed. In both cases the spindle continues to run until I stop it. After resetting the alarm when I attempt to do a “start from” the end line was not noted so I either have to attempt to guess where to start or just start from the beginning. Extremely frustrating. Any idea? Running an Altmill MK2 4x4, gcontrol computer with gsender 1.6.3. All software is up to date.
@Donminn I believe Alarm 10 can be the last alarm shown in a series of alarms. What does the console show? It’s possible there was another alarm before that one.
@Donminn Something you can try is enabling check mode. This will go through the entire file and display it in the visualizer as it “runs”. There mill doesn’t actually run during the check. You might be able to see where it fails.
Thx. I’ll give it a try. I looked at the notifications and didn’t see any codes before the error 10. :person_shrugging:t3:
After doing all the suggested maintenance steps like oiling, greasing, tightening, I upgraded to 1.6.4 and was still expecting the problem. It occurred to me that I had heard different weird glitches resulting from a wireless Xbox controller. Though I had not experienced any of these I decided it warranted a try. I completely disconnected the controller by pulling the usb dongle. Apparently that was the issue because I have run several longer carves since and had no problems. I have now joined the long list of users that are waiting hopefully that Sienci will eventually get around to resolving that issue.
@Donminn Any updates on this? Another user had what appears to be a similar issue.
@Donminn While it may not help, you could update to gSender 1.6.4.
I’m moving this to the gSender category.
Thought I should update this thread. I did submit a service ticket on this. Was advised to go through all the service recommendations available. I worked my way through them all, completed all the maintenance recommendations, and made sure all software was up to date. I briefly thought the problem was with the wireless controller so I removed the dongle but alas, the problem continued. When checking the history I found that every time the error 10 was preceded by a x-motor error. Since I had purchased an extra stepper motor to have on hand I decided to switch the x-motor just to see if it would resolve the problem. I have now completed the 10th carve since replacing the motor with zero problems. I’m pretty confident I had a defective stepper motor. I purchased the machine in Jan when the warranty was 90 days. I assume the updated warranty is not retroactive. However, I’m pleased to have resolved the issue.
