My AltMill 2.2KW spindle won’t operate if I select “H100” from the drop-down. I thought I had the startup sequence wrong, but I don’t believe so. I typically:
Start Gsender
Power on spindle
Power on SLB (E-stop set)
Release E-stop
Connect to SLB USB in Gsender
Click unlock in Gsender
Upon startup, it has “Default” selected under the Spindle/Laser tab, which works fine. If I choose “H100” from the drop-down, the spindle will not spin. If I leave it at “Default”, all is well.
This is a problem when I’m running my OptLaser setup because when switching back from the laser to the spindle, I can’t choose “Default”, only “H100” is visible in the drop-down list. That makes it impossible for me to run a laser job first and then make cuts with the spindle.
Also make sure you have latest firmware of 20260525 Firmware & Flashing - SuperLongBoard since I thought there were some updates relating to spindle selection.
Firmware was indeed behind. I’ve now upgraded to the latest for the AltMill SLB-EXT. (20260525) It seems I can switch back and forth between spindle/laser without issue. Thank you!
Note: I’m using the OptLaser setup so my previous configuration was my secondary spindle set to SLB_Laser. It seems that option has been removed in the latest firmware and is now PWM2. (not well documented from what I can tell)
