Altmill Y2 Limit Sensor
I have an issue with the Y2 limit sensor on my Altmill, wondered if anybody could help?
I have all the limit switches plugged in correctly, and I am using a screwdriver to trigger them to test they are all working. All the switches work, other than Y2, which I cannot trigger.
If I plug the Y2 sensor into the Y1 port, then I can trigger it, so clearly the sensor is not faulty.
If I plug Y1 sensor into the Y2 port, then I cannot trigger the Y1 sensor.
Clearly the issue is not the sensor, but I also doubt its the SLB-EXT. Sienci provided me a replacement SLB-EXT to try and fix this issue amongst others, and I have had this identical issue on both SLB-EXT boards.
Are there any settings/config which could be causing this?
Hey Harry,
I have gone back into the manual and found a remark at the limit switch part of the slb manual. I have no idea if it is still valid or needs updating, but it might be that this is the source of your problem?
The latest post by Chris on auto squaring (needing the 2 y sensors) was Jan this year. It was an early beta version. He even released a -at your own risk- trial in the last post in this thread here:
Please note the pretty clear warning posted on using this u tested feature:
Thanks, so if I home the Y axis does it only need the left Y1 sensor?
Also, if you are correct, and it’s not required or enabled, it seems strange nobody else has found this issue and Sienci themselves haven’t pointed it out to me, but instead sent me a replacement SLB-EXT?
The altmill instructions even say to plug both in.
Further to this, this section of the altmill resource page specifically requires you to have both sensors, and states that as default the altmill is setup to have both Y sensors active.
Yeah, that proves again I should stay in my lane and keep out of altmill/slb/lim switch topics. Sorry for the mix-upping.
Oh well, it comes from a good heart, they say.
So I also noticed the exact same thing and did the exact same troubleshooting and then found this post. So am I to assume, the TLDR is this: the Y2 probe does not trigger the Estop by design and is instead used as part of the dual homing feature?
I found that whilst holding some metal near the sensor didn’t trigger the alarm, the light did light up on the actual y2 sensor showing it was working.
@Mohjo @HKingUK @Spamming_Eddie @_Michael
Timely post. There’s a post that I made yesterday questioning that behaviour for Y2. When testing something for another user, I found that Y2 does not trigger an alarm when you approach a metal object. I didn’t know if that was by design or not. I sent Sienci a support question but haven’t heard back.
