After updating to 1.6 I flashed the updated firmware successfully to my slb-ext to 20260318. Now my auto probe is throwing an alarm 4 every time I try to xyz probe. I have tried setting both invert and non invert in config. Makes no difference. Interesting the made contact dialog box shows that it is green even though I havenāt touched it and no matter whether I turn that feature off or on in config. The auto probe was working perfectly twenty minutes ago under 1.6 and stopped working just after the re flash so I assume it changed some settings? So far this is the only feature that isnāt working.
Never mind. Found out that tls had to be inverted in config as well. Now it works!
