I would like to know how to use the AutoZero touch plate. So I watched a video on how to do it. After trying to use it nothing happened. I am assuming you need to attach the plug to the Sienci control board to the probe ground connection. Then plug the wire into the touch plate that is near the AutoZero touch plate. Then attach the magnet to the spindle nut of the router. Touch the tip of the bit to the touch plate and it should work. Do I have to press a start button? Do I have to have a program loaded? I am terrified of jamming the bit into the touch plate.
@Dean Did you go through the documentation?
You need to start the probing routine in gSender. All your other steps look fine.
Duh. Thank you very much! The bit did not crash into the touch probe. Thank goodness! Next question. Now that I ran the probe and it touched off what does that tell me? I just did the Z only.
@Dean It set the zero location of your x,y, and/or z relative to your workpiece. That zero needs to match the zeros your define in your CAM program.
Thanks for the reply! So I see probing XYZ the readings go to zeros. So that is just a start point then? If you set the XY datum position to the left bottom that is where the machine will start. If you select the XY datum position in the center of a project and you have ran the probe program on a corner what happens?
@Dean nothing good will happen ![]()
The zero position you define on your machine has to match the zero in your CAM program. If that’s on the center of your project, then you need to zero your machine on the centre of your workpiece too. I probably would not use the AZTP for X0Y0 in this case. I’d just use it for Z0. For X0Y0, I’d eyeball it. Using a conical centerline gauge in the spindle can help.
Thank you for the responses. You have been a big help! Centering your suggestion sounds like a great idea.
Dean, if possible, DO NOT attach the AutoZero probe to the spindle nut. If you forget to remove it, in a flash you will have a super dangerous situation. How I know you ask? Mistakes happen and often they can be very dangerous. I was lucky and only had a scratch on my shoulder. I could have lost an eye.
I have a spindle; one probe (the red wire) is attached to the AutoZero probe block, and the other end (black wire), with the magnet, is attached to the leg of my Altmill CNC, NOT the nut on my spindle. You can attach the magnet to any spot on your CNC that has an electrical path to the spindle.
@Jgt1942 Ouch. What happened? The cable twisted around the spindle shaft and the AZTP went flying?
You hit the nail on the head.
Looking back, I still question how in the heck did I goof and leave the magnetic attached to the spindle nut. After all, it is VERY obvious; I should have seen it; But being a newbie (I still think I’m a newbie), and fearful of making a mistake, I did just that and made a mistake.
The AutoZero wires were VERY tightly wrapped around the spindle and as you stated, the AZTP went flying. I was setting on a stool with my face close to the spindle. After all, I really needed to see what was going on (another dumb mistake). When I clicked the START icon in gSender it was over before I realized what had happened. Something that went flying hit my right shoulder and produced a small cut.
I’m on a mission to inform others NEVER, NEVER, NEVER attach the magnet to the spindle nut.
@Jgt1942 Excellent advice, John. Those with machines using delrin wheels will need to ensure that they choose a spot to place the magnet that has continuity to the router bit. Your placement on the leg works with the Altmill since there is a continuous metal contact/ground among all the altmill’s parts. That is not the case with a Longmill other than the Mk3.
Thanks for the replies. The auto zero works.
OMG! I read your post multiple times and I couldn’t figure out how leaving the magnet on could grab the AZTP and how @Chucky_ott figured it out so fast. Then I went and looked at the shop and I see the wires are a pair.
I had forgotten having the magnet wire run through the cable chains isn’t the typical way things are done. I didn’t even consider that it might be safer. I did it because of this.
Anyway I’m glad you didn’t get hurt really bad. When you mentioned losing an eye I was thinking the nut went flying. With the whole touch plate flying you could lose a head! Hurt Bad!
EDIT: I never considered that I might have continuity where the magnet is stored. My LongMill has plastic wheels and backlash blocks but maybe there is a path through the linear bearings or a place to store it that has continuity? I’ll have to check that out. Good suggestion.
EDIT2: No dice! On a LongMill Mk1 with Makita router the motor shaft, nut and bit are the only parts with continuity. You mentioned spindle specifically so maybe everyone knew it wouldn’t work with a router but it was a very exiting five minutes thinking I might not have to move my magnet anymore.
Jgt, yer not allone. Can I leave it with that and never mention it again?
I agree; not everyone has continuity, especially if using a router. However, it may be possible to create a permanent continuity path. Possibly, some screw or bolt might have continuity, and it would lead to a solution. I suggest that those using a router also check with the mfg of their router and ask about continuity to the collet. They might have a solution. However, the mfg might be fearful of offering a solution that might be interpreted as recognition of a hazard. If nothing else, those with a router should be aware that placing a wire with a magnet introduces a hazard if attached to a router collet. Safety in the shop should be a #1 priority for all of us.
