Can not get correct spindle speed with Gsender
After connecting Huanyang 220V water cooled spindle VFD to Gsender and making the settings shown in the Sienci Technical manual the spindle runs about double speed that is shown on the Gsender display. With the left slider at 100% and right slider at slowest (7500) the spindle is running over 15,000 and with right slider moved to 11,900 or anything above spindle is running 24,000. Spindle starts when a gcode is run and waits the appropriate spin up time and stops when finished. PD070 is set to 1 for 5V. Any ideas?
Sounds like you are not using the RS485 interface. Why not? I am using the Haunyang with RS485 and it works flawlessly.
If you are using the voltage converter I think the SLB puts out 0-10 volt versus 0-5.
Len
I am using the RS485. I have also tried the RJ11 with the same result. I am under the impression that the SLB output is 0-5V however in case that is incorrect I did try the VFD PD070 setting of 0 which is 0-10V, same result.
You may be correct in the voltage the SLB puts out. Did you connect the VFD RS485 to the B+ and A- terminals on the SLB. Did you remember to crossover between the VFD and SLB?
How are you measuring the actual spindle speed?
Yes I did crossover between the VFD and SLB. Rpm wes measured with an optical digital tachometer and that matched closely with the frequency conversion on the VFD.
Being that your Huanyang spindle is working well could I ask a few questions? To begin with is yours 220V? Mine is a HY02D223B. What are your, PD001, PD002, PD163, PD164 and 165PD?
I understand that the RS485 is a digital output, my HY manual mentions Comunication control RS485 but then the PD070 settings are analog. I do not see any settings regarding RS485 or digital. Do you happen to be using an digital to analog converor? Thanks for your time.
Allan
Mine is indeed 220. Not sure what the model in but it came from Amazon a few years ago. I do not use a digital to analog convertor - everything via RS485.
PD001=2
PD002=2
PD163=002
PD164=2
PD165=3
PD170=00
I have all of the PD settings recorded in spreadsheet if anyone is interested.
Len
I would cetainly appreciate if you could provide all your PD settings. Are you using Gsener 1.5.6?
Allan
Gsender 1.5.6
Here are all the PD settings……
PD SLB Cont.
000 0
001 2
002 2
003 199.91
004 400.00
005 400.00
006 2.5
007 0.20
008 220.00
009 15.0
010 8.0
011 120.0
012 0
013 0
014 10.0
015 10.0
016 20.0
017 20.0
018 40.0
019 40.0
020 80.0
021 80.0
022 0
023 1
024 1
025 0
026 0
027 .50
028 .50
029 0.0
030 0.0
031 2.0
032 5.0
033 150
034 0.5
035 NULL
036 NULL
037 NULL
038 NULL
039 NULL
040 NULL
041 08
042 5.00
043 0.0
044 02
045 03
046 14
047 22
048 24
049 23
050 01
051 05
052 03
053 00
054 0
055 100
056 0.0
057 0.0
058 0.0
059 0.5
060 0.0
061 0.0
062 0.5
063 0.1
064 001
065 001
066 00
067 NULL
068 NULL
069 NULL
070 0
071 20
072 400.0
073 00.00
074 0
075 0
076 0
077 0
078 0
079 0.01
080 0
081 0
082 0
083 0
084 0
085 0
086 15.00
087 20.00
088 25.00
089 30.00
090 35.00
091 40.00
092 0.5
093 10.0
094 15.0
095 20.0
096 25.0
097 30.0
098 35.0
099 40.0
100 45.0
101 10.0
102 10.0
103 0.0
104 0.0
105 0.0
106 0.0
107 0.0
108 0.0
109 0.0
110 0.0
111 0.0
112 0.0
113 0.0
114 0.0
115 0.0
116 0.0
117 0
118 1
119 150
120 000
121 5.0
122 NULL
123 0
124 000
125 1.0
126 0
127 NULL
128 NULL
129 NULL
130 0
131 60
132 005
133 60
134 060
135 095
136 30
137 80
138 20.0
139 20
140 NULL
141 220.0
142 8.5
143 04
144 3000
145 2.0
146 40
147 0000
148 NULL
149 NULL
150 1
151 0.0
152 1.0
153 0
154 0.5
155 00
156 100.0
157 5.0
158 0.0
159 0.0
160 0
161 100
162 000
163 002
164 2
165 3
166 0
167 0
168 0
169 NULL
170 00
171 7
172 00
173 255.0
174 11.0
175 0
176 0
Unfortunately setting for the most part the same, tried the couple that were different but no change. Thanks for your help.
Allan
