Carving backwards, also, no code line numbers
After installing the update, everything I attempt to carve/etch is mirrored! The orientation is correct in Vectric and the gsender visualizer, but it still carves backwards (mirrored).
Also, the code line numbers have disappeared. I accidently hit a limit switch that shut the machine down. I received the nag saying I could start from where it stopped; however, when I went to the screen that should have said where it stopped, It said I could restart and that the machine stopped at LINE ONE! I was 30 or 40 thousand lines into these projects and had to start from the beginning because the the code lines weren’t listed, just the code.
Any help will be greatly appreciated. Thanks
Sounds like your machine axis are wired/configured wrong and the mirrored one got inverted somewhere…
