Depth of cut is deeper than expected
yes, my mirror image issue is resolved. I have tried 1.5.7 but very slow/difficulty opening. so I tried edge as well. I’ve also got 1.5.2 loaded and trying it as well.
after figuring out my mirror issue by accident i now have a new issue (sorry for being a pain- i don’t mess with things once they are set up and running correctly) but for some reason now my dept of my cuts are cutting deeper than they should. for my puck thickness does it need to be a - value?
and honestly, i’m not even using a puck, i’m using the paper method off the surface. but that is not an option in the settings.
@lkmcclain7357 I’ve hived off your new issue, Larry, and created a new topic for it. I’m sure that someone will be able to help.
I will just add that you cannot have both 1.5.7 and 1.5.2 runnning on the same pc. The one loaded last will overwrite the earlier one. You can have Edge and gSender on the same PC, though.
