I am trying to surface a cylinder and gsender will start, then within 3 secs stops with “Door” error
Has anyone else had this issue?
@Robo I never heard of that error before but a search of this forum brings up this: Check safety door issues - Community Support /
Something’s Up - Sienci Community Forum
I don’t know which pins the post refers to. Maybe the SLB documentation mentions something.
Found this re status lights on the board
Troubleshooting - SuperLongBoard
I read that, but I have the vortex rotary post processor installed.
I am running gsender version 1.5.7
@Robo Have you seen this: Safety Door Triggering – Sienci Labs
I had that error, and I could not reset.
I had to shorten 2 pins on the board, then i could use it again.
There is a safety door mount plug on the board, there you can shorten the 2 pins.
Edit: Can see that there is a link for that up in the tread.
Its strange that i have never had that problem in the past when surfacing. I carved the skull with no problems.
The “Door” issue has disappeared. Now I am getting an error code 2(Bad number format).![]()
(Header)
(Generated by gSender from Sienci Labs)
G54
G20 ;inches
G1 F118.11
G90
M3 S17000
(Header End)
(*** Layer 1 )
G0 Z1.5
G0 X0 A0
G0 Z1.38 F23.622
G91
G1 A-360 Z-0.410 F980.754
G1 A-360
G1 X2.500 A-24000.000 F6976.500
G1 A-360
G90
G0 Z1.5
G0 X5 F23.622
G0 Z1.38 F23.622
G91
G1 A360 Z-0.410 F980.754
G1 A360
G1 X-2.5 A24000.000 F6976.500
G1 A360
( End of Layer 1 ***)
G90
G0 Z1.5
G0 X0 A0
(Footer)
M5 ;Turn off spindle
(End of Footer)
