Altmill 2x4 MK2 with SLB Superlongboard and Sienci 1.5KW Spindle, Gcontrol and Gsender.
All working fine and suddenly in the middle of a job, I get an E stop error.
When I restart and activate the E stop, I get a beep and 2 of the LED lights quickly flash. Then nothing. The lights won’t stay on. I checked all the wiring, unplugged, re-plugged, multiple restarts of everything in different orders. Nothing seems to help.
Any insight as to what me happening and how to fix would be great.
Also- I’m on the last procedure of a big job and need about 5 minutes more of machine time! Anyone know of a way to temporarily bypass the E stop button?
Using the troubleshooting guide for Alarm 10 / Machine locked when E-stop is released I found that when the power to the Z motor was disconnected, the e stop button was able to clear the error.
I spoke with Craig at Sienci and he recommended swapping the Z motor for a different motor to further isolate what the problem might be. (All 4 motors on this Altmill are the same.)
@HonestKnifeCo When you swap the motors, make sure the dip switches are set for that motor’s position. I don’t know if they’re different but it would be outlined in the installation documents.
