Is there a way to add to the Console Tab/Window a "delete/erase feature, much like what Candle has? When I change settings within GRBL, it’s confusing to see all the previous settings. I’m used to Candle’s blank screen when I put a new setting in. Thanks
@DMJ Welcome to the group.
I’ve moved your question to the gSender category assuming you are using gSender. If you are not, please let me know.
It’s a good question. I don’t know how to do it either. When I am playing with settings using Console, I enter a string of garbage, for example gggg, the hit enter. That gives an error. Then, when I make changes, I can scroll back to that line of garbage to confirm that the changes took.
This should be an easy add for @KGN and the team. The code to clear the terminal is already there. They’d just need a button to send the command. I’d submit a pull request, but I’ve had a hell of a time with webpack dependencies and the like when I’ve tried to build gSender.
EDIT: Here’s the relevant code.
Maybe something like this added to the render():
<Button
onClick={() => this.clear()}
style={{
margin: '0px',
height: '100%',
border: 'none',
borderRadius: '0px',
borderLeft: '1px solid #9ca3af',
<i className="fa fa-trash" />
</Button>
This is something we’ll look at as an Edge feature.
4 posts were split to a new topic: Building gSender
Thanks for the request @DMJ , this was since implemented!
