g sender 1.6.1
30x70 longmill
sienci spindle
vectric vcarve pro 12.509
task: pocket a .25" deep pocket in a .75" board
zero of the surface and center of work piece
end mill plunges full depth .75" checked all my setting everthing checks out what is going on?
@2Tall In Vcarve material settings, Z0 is set to the material surface, correct?
How did you set Z0 in gSender?
I agree with gwilki. Make sure you have Vectric configured for material surface not machine bed. It’s easy to miss especially if you switch back and forth.
