Error 25 problem
gSender halts randomly with error code 25. Code IS CORRECT and Lock icon restarts job with no problem. Port is set to COM3 usb(115200). Happens 3 or 4 times in 6,000 lines of code. This is my first job. Any idea what causes this?
I switched to Ethernet as the quality of USB cables is variable and ethernet handles interference better.
Thanks, I had guessed that and have a new shielded USB cable on order with Amazon. Next will be using your suggestion. Again, thanks for your quick response. I didn’t expect an answer so quick.
